Is the RBD Constraints from Rules node's Connect Type: Surface Points used to connect separate mesh parts of a model together?
e.g. assume the model is consists of a sphere and a box just touching.
Is this a way to connect them, if so could someone explain the setup?
Or should I use Glue constraints?
Use Surface Points to constrain model parts?
432 1 2-
- litote
- 269 posts
- toadstorm
- 405 posts
If they're meant to connect together and act as a single object, and you don't need them to separate during the sim, give both objects the same `name` attribute and they'll solve as a single piece in Bullet. If they do need to separate from each other, use a constraint.
