APEX Editgraph: How to unpromote controls
   697   4   0
I want to use the autorigcomponent node with a editggraph in the second input to modify a existing APEX graph and I want to "unpromote" existing controls.is this possible?
just unplug the t r s promotions of the joint from the input in your rig graph
I want to do it with a "APEX Autorig Component"-node, that uses a "APEX Edit Graph"-node as second input, so I have to unplug it with a graph tool.
Edited by sanostol - Aug. 1, 2025 09:35:05
sanostol
Currently, there are No graph namespace node to delete a wire connection in apex graph, i'll submit a rfe for this.
The best workaround for this for now will be to create a new null node using the addnode node, use findandconnect node to connect the __spare__ variadic output to the t/r/s input (it will reroute the input promotion wire to the null node), and delete the null node using deletenode node, I hope this helps!
Edited by Umang_Raj - Aug. 1, 2025 12:01:57
Thank You, that helps
