The Asset Catalog has these buttons to show tree view or split layout, but i couldnt figure out how to use it, tried searching everywhere but couldnt able to find anything about this,have anyone used these if yes can you share some insights on how to use these?
Asset Catalog - Categories, Tree Structure.
1251 10 3-
- Mohanpugaz
- 174 posts
Hi All,
Mohan Pugaz
movfx
movfx
- Mohanpugaz
- 174 posts
Ah, Okay, I figured it out myself,
If you have multiple database files in HOUDINI_PATH, then thry shows up as categories/treeview
hope it helps someone crossing same path
Edited by Mohanpugaz - Sept. 7, 2025 23:56:25
Mohan Pugaz
movfx
movfx
- Mohanpugaz
- 174 posts
However Single Database file has sub directories here in Houdini's material database, how can i replicate something for my custom database do i need to dig in and learn some database management or is there a simple way to do this in Houdini itself without having to edit database file?
Mohan Pugaz
movfx
movfx
- Mohanpugaz
- 174 posts
I got it working
Mohan Pugaz
movfx
movfx
- raincole
- 692 posts
- Mohanpugaz
- 174 posts
raincole
How did you create the subfolders?
I modified the database file with python. I couldn't find builtin methods to do this.
Mohan Pugaz
movfx
movfx
- raincole
- 692 posts
- Mohanpugaz
- 174 posts
yeah kinda painfull, but this is first version with the tree view in asset catalog.I really hope that they will definitely include subfolder creation and more features for the asset catalog in next version.
Mohan Pugaz
movfx
movfx
- tomwcutler
- 28 posts
hey - how do you get your custom databases to show up - can i see your .env?
i've tried HOUDINI_ASSETCATALOG_DB_FILE="C:\Users\User\Rendering Resources\Houdini\asset\" and HOUDINI_ASSETCATALOG_DB_FILE="C:\Users\User\Rendering Resources\Houdini\asset\assetCatalog.db" also with ;&
..but i get "invalid data source"
- Mohanpugaz
- 174 posts
You can just use this option to load custom database
Mohan Pugaz
movfx
movfx
- tomwcutler
- 28 posts
Hey - yes i realise this, but how can i get the custom database to load at startup instead of the built in one?
if i place a db in the user folder, this works for me: HOUDINI_ASSETCATALOG_DB_FILE="superassets.db"
but using any kind of path does not: HOUDINI_ASSETCATALOG_DB_FILE="C:\Users\User\Rendering Resources\Houdini\asset\superassets.db"
