Hi
I can't find Houdini 20.5.684 production build !
1728 16 0-
- rachid
- 12 posts
- CYTE
- 805 posts
- rachid
- 12 posts
- BabaJ
- 2177 posts
- rachid
- 12 posts
yes clicking Show All and this is what I get no houdini 20.5.684 for windows!
few week ago I don't have to click Show All button!
There is nohoudini20.5.684 for windows
[postimg.cc]
[postimg.cc]
- BabaJ
- 2177 posts
- rachid
- 12 posts
No I'm not interested for houdini-qt6 just regular houdini-20.5.684 win64 (py311)
few week ago it was in production build, I don't understand SideFX's philosophy behind all of this,
they removed the latest version, which was 20.5.684, and replaced it with an older version, 20.5.654
How is this possible?
- BabaJ
- 2177 posts
- rachid
- 12 posts
I don't know what you're trying to prove, it seems you're not reading carefully.
One time you showed me houdini Qt, and this time you're showing me houdini Py 3.10, yet I clearly stated: houdini 20.5.684 py 3.11
Again, Why did SIDFX remove Houdini 20.5.684 py 311 and replace it with an older version, Houdini 20.5.654 py 3.11?
Can you answer this question?
- BabaJ
- 2177 posts
You said originally:
"I can't find Houdini 20.5.684 production build ! "
you also said in your last post:
"they removed the latest version, which was 20.5.684, and replaced it with an older version, 20.5.654
How is this possible?"
But you also added 311 to your comments.
It's likely that you thought there was a 311 but never was.
There is only 310 for all versions, not just the two your were asking about, i.e. 20.5.684 vs. 20.5.654
- rachid
- 12 posts
Oh!
Yes, I added py3.11 to explain, so you can tell the difference.
houdini-20.5.684 win64.exe (without py3.11) is the py3.11 version. You should already know that
Now Explain to me what you see in the picture, py3.10 or py3.11? of course py3.11 So please don't talk nonsense.
I'm using Houdini py3.11 for a long time...
[postimg.cc]
[postimg.cc]
Edited by rachid - Nov. 27, 2025 12:58:17
- BabaJ
- 2177 posts
Did you add 311 yourself at some point to overide the default Python version?
I don't use python much but I do recall in discussions on the forums of people specifying the Python version they want to work with.
What you are showing here is not what's available on the download page.
Maybe someone who works regularly with Python would have noticed the same thing, if true(SideFX removing 311 versions).
Otherwise, if you want to be clear - just go to submit bug/rfe page and ask SideFX why they removed 311 default versions from the production builds.(If they did).
And if they did, again, pretty sure you can just download the .684 version you want but in preferences(or wherever Python alternive versions are specified); Set to your desired Python version.(311, off course with that python version download and placed where it can be accessed).
No need to be 'snappy' - You weren't actually clear from the start of your first post, you only added 311 to the mix in later comments.
- rachid
- 12 posts
My god! What's wrong with you, man?
Excuse me, this discussion has become pointless.Seriously, you're talking nonsense!
Now SIDEFX has added it to the daily build.Someone in the team isn't doing their job properly
what was production build after two months becomes daily builds
[postimg.cc]
Python version
[postimg.cc]
[postimg.cc]Python version
[postimg.cc]
- BabaJ
- 2177 posts
- rachid
- 12 posts
I didn't say anything wrong to make me change my attitude. You're trying to drag me into another discussion and get off-topic. Furthermore, I insist once again that someone in the team isn't doing their job properly. Not even 10 minutes after my comment, they removed version 20.5.684 from the daily build.
You should also know that ADSK does not deliver HtoA for Dailybuild, only production build
How is that possible then?
[postimg.cc]
After all, the question still remains
[postimg.cc]After all, the question still remains
- johnmather
- 679 posts
The build was removed by an automated system accidentally. We have re-uploaded it here: https://www.sidefx.com/download/download-houdini/135994/ [www.sidefx.com]
A daily build with the same version number is the same as a production build with that number. The only difference is that more QA has been performed on it before we bestow the title of "Production Build". We are working on making it appear as a production build once again.
With issues such as this, it's best to contact support so that it can be routed to the correct person faster.
Edited by johnmather - Nov. 27, 2025 14:04:32
- rachid
- 12 posts
