I decided to play around with the new Houdini 21 Live Simulation mode -- maybe try to transfer some Touch Designer concepts over -- and I am not getting any results.
I can't seem to find any documentation about it online and it seems to simply not work as expected. Am I wrong in thinking this is a feature that's just in alpha or something?
I created the simplest possible setup: point with an add SOP into a popnetwork (with randomized velocity on the popsource). I then enable the "Live Simulation" mode on the dopnet and press the live simulation button.
The "Live tick" parameter starts iterating upwards, however it is creating a new POPOBJECT on every tick, quickly filling up the memory (view image).
(and naturally the velocity remains the same for every iteration of the tick)
I am probably doing something catastrophically wrong. Is live simulation just for COPs or something?
Help me understand the new Live Simulation mode
170 2 1-
- chilby
- 19 posts
- chilby
- 19 posts
- AslakKS
- 291 posts
You need to base the Pop Object's Creation Frame on the live tick instead of frame number.
- Set Creation Frame to ch("../continuouscook_tick")==0
- Enable Live Sim on the DOP net
- Make sure Live Tick is at zero
- Enable Live Nodes in your houdini session
- Do step 1 & 3 if you add other dop objects to the sim.
