HOM save geometry
   5974   2   2
Anyone happen to know if you can save the geometry a SOP is generating to file via HOM (same as RMB->'Save Geometry')? I am not finding anything in the docs…
There is a command:
hou.Geometry.saveToFile()
but it's still not documented yet, not even sure if it works…
You can always use old hscript command: opsave. It saves appropriate data format for a specified operator, so simple:
hou.hscript('opsave /obj/geo1/null1')
should work.
hope this help,
sy.
To do it from Python, you would write:
hou.node('/obj/geo1/null1').geometry().saveToFile(“file.bgeo”)
