Hello to all,
I was doing a bit of learning, and I watched 2.takes_rops tutorial movie,
everything went fine until I made a shadow pass take. Every time I try to launch render I get this error:
mantra: Singular matrix detected “/obj/grid_object1”, object ignored
and output is black frame with no shadows in alfa.
I went back'n'forward few times without success.
Things I noticed that are different then in the video are:
In shadow_pass mantra node I have Expression stack error
Same error shows up in grid_object1 node
here's a file:
it is v9.0.803 on winxp
shadow pass + takes question/problem
5151 3 1-
- djorzgul
- 235 posts
- symek
- 1390 posts
I don't know what is the reason of this behaviour, maybe there were some changes in Houdini. But in general
means that object has a bad transform matrix applied so mantra can't evaluate it. It seems in this case that expression error in shop_path causes Houdini to stop exporting proper object to ifd file. So there is no valid object in ifd - although it's was mentioned.
All I did is reapplying shops for all error prone objects - I had to also recreate some of them and it woks fine now. Still have no idea why it's like that.
hope this help,
sy.
hope this help,
sy.
- probbins
- 1145 posts
There seems to be a bug with the Shop/material path.
I can get your shadowmatte to work if I use the menu selector and choose your material via the path /obj/shopnet1/material1, no single quotes.
The Shopnetwork node will still show an error but the render is correct.
You perhaps didn't create the material correctly. I recreated the shadowmatte material by calling in the vex shadowmatte node, then Shift-C to collapse it into a material, I also promoted the parameters up to the material although that isn't essential. This cleared the error from the Shopnetwork node.
“everything is coincident”
- djorzgul
- 235 posts
