i'm using h9. learning how to make a fractured obj. i attached the hip file.
problem 1 : before the box hit the floor the surface (as a result of the extrude node) is not smooth, it looks segmented. how to fix this?
problem 2 : after it hit the floor, the pieces of the box are intersect each other, even after i increase the division in the collision tab. how to make the simulation to be more accurate.
anyone can help ?
thanx.
how to create smooth fractured obj
4199 2 0-
- metaclay
- 122 posts
- eetu
- 607 posts
1) That is because the objects have smoothed normals. Put a facet SOP after the partition SOP, enable “Unique points”. (which leads to an additional question; is there a way for polygons to have independent normals without duplicating the points? vertices?)
2) In your fractured object DOP, change Collisions -> Surface -> Surface representation from “Points” to “Edges”
eetu.
eetu.
- Bandu
- 12 posts
