I want to breakup a polygon into its faces. E.g. the faces of a polygon grid. I'd like to extrude the objects later and play around with rigid body dynamics.
Unfortunatly I dont know how to separate the single faces of an polygon in a way I can use them later for simulation. Any hints are very welcome. Thanks.
Breakup a polygon
14499 7 1-
- haggikrey
- 45 posts
- jason_iversen
- 13000 posts
Here is one example.. Unique the points to separate the faces, extrude them, group them based on connectivity, rbd-fractured object them into an RBD simulation.
- haggikrey
- 45 posts
Thank you very much.
Well, maybe it is just me but I find it a bit hard to understand whats going on here. Maybe only because the names of the functions are a bit different from other tools. Sorry if I ask really basic questions, but I'd really like to understand what I'm doing.
So you first have a grid. This grid has shared point and edges I want to seperate.
The separation is done with “fuse”, correct? This means that I dont have any shared points any more.
Next the “connectivity” node will make a connection between all points that share the same polygon and create an attribute named “class”. So why to I have to do this? The polygons are seperated anyway. Maybe it is only because of the “class” attribute which is needed later?
Finally the “partition” node creates a group of primitives which can be modified later with dynamics that works with the single objects of a object group.
- haggikrey
- 45 posts
- haggikrey
- 45 posts
- buki
- 1773 posts
hi!
by default rbd object is set to volume collision model, so You have to have a closed volume for proper collisions, just turn on the guides on the rbd object and increase the divisions to get a more precise representation of your closed volume collision geometry
daniel bukovec | senior fx td | weta digital
qLib -- http://qlab.github.io/qLib/ [qlab.github.io]
- haggikrey
- 45 posts
- Simon
- 2199 posts
haggikreyYou will find with a lot of houdini nodes that they can do more than one job. Often they also do the reverse of the main operation. So fuse can also unfuse. You need to look at the parameters to see exactly what it is doing. In this case it will be making points unique.
haggikreyThe connectivity sop just builds the class attribute, as you noted, the class attribute stores a number for each set of connected things, points or primitives.
haggikreyCorrect. This only works though because of the previous connectivity sop which created the class attribute that the group sop is using.
