Rotating objects, using group names
   4757   6   1
I create box, duplicate it and have some groups.
How can I rotate these objects, using group names with the help of one operator? One follow another…
may be another variant?
[img230.imageshack.us]
box_Groups_rotate.hip (63.1 KB)
Hey,
I am not exactly sure what you are looking for (can you be more specific please) You can try foreach loop, separate each group and extract the number from the group's name. This will be used as a value for rotation…. Is it what you are looking for?
At some point it would be good for you to switch from groups to attributes - it is much more flexible way to work with complex geometries.
Cheers
kuba
I'm looking something like this (in attachment)
Im not familar with houdini specifically in foreach node Can you post some example about this node - there is no examples in help
one more question - if I create curve with numbered point on it, what attributes must I change to rotate each point?
point node have NX, NY - normal directions, and then I type $F - number of frame in place of N*(Add Normal), nothing rotating, or rotating strange but number of frames is changed
I want to change point normal direction depending on frame number… (one frame - one degree) HOW???
may be it have (from 1-to 0) value?? or in radian? or vector?
thanks for replying
box_Groups_rotate_2.hip (72.5 KB)
Hey Piter,
I think the easiest way is to use copy stamping. Have a look at the hip file, hope you are looking for something similar? Middle click on xform5 to see my comments on that node.
When it comes to normals it is possible but because you want to drive rotation with frame number, it will be quite tricky to transfer this value to normals (which consits of three-components). On the other hand that should be pretty easy in CHOPs
Please note that you get get similar behaviour with CHOPs, have a look at sideFX tutorial section and watch Introduction to CHOPs.
and good luck
kuba
box_groups_rotate_2_205_stamp.hipnc (70.2 KB)
Thnks, man!
I don't programming for 11 years, and now I'm coming back, - its very interesting - programming hyperspace tunnels or dancing galaxies ))
Houdini - the BEST!!!
[img98.imageshack.us]
are your ancestry on the picture? I like the wings…
Ha Ha!
Nice one, yep, this is definitely Kuba's grand grand father. I can see it from his eyes…
The name of such an army was: Husaria
http://en.wikipedia.org/wiki/Polish_Hussars [en.wikipedia.org]
and little more here:
http://pl.wikipedia.org/wiki/Husaria [pl.wikipedia.org]
in polish…
cheers,
sy.
skazkaPiter
Yep, that's my great*28 grand dad
The wings have their technical reason, the sound of rattling feathers scared opponents cavalry which was the major influence in 1683 - Battle of Vienna. hmmm, nice times…..
