Hi!
Please, tell me, what is the MB Styles?
in help:
Motion Blur Style
The type of motion blur. You can choose either a trailing, centered, or leading blur.
But, what`s the differences of this styles?!
Motion Blur
8474 6 1-
- envil
- 45 posts
- wolfwood
- 4344 posts
It denotes when the motion blur samples are taken.
Assuming $F is your frame and you shutter is 1
Rendered Frame is Centered:
$F-0.5
$F+0.5
Rendered Frame is Trailing:
$F
$F+1
Rendered Frame is Leading:
$F-1
$F
Traditionally ‘trailing’ has been the default in most renderers. But there have been instances where ‘directors’ have found it confusing and prefer centered.
$F-0.5
$F+0.5
$F
$F+1
$F-1
$F
- envil
- 45 posts
Thank you!
I thought about this..
ops:
I have a problem with render MB in other differents renders.
While I render a reflectible surface with animation and MB, reflection on object is blurred with same object, as if reflection there was a texture. It`s wrong! As if I render MB on micropoligons type of render in mantra.
I discover the differents renders, Vray, MentalRay, PRman, but result is one and wrong
BUT! :!: … but in mantra all fine. I`m set raytracing type of render ang reflection is not blurred!
Are you have an idea, what this???
sorry for my english, please…
ops:
ops: I have a problem with render MB in other differents renders.
ops:
- lor
- 292 posts
- lor
- 292 posts
- lor
- 292 posts
- neonshaun
- 31 posts
