possible memory leak in CVEX_Context
   3329   3   0
It seems the destructor for CVEX_Context doesn't completely clean up.
This causes memory usage to grow like crazy:
for (int idx = 0; idx < num_shaders; idx++)
CVEX_Context cvex;
// … set up inputs
if (cvex.load(argc, argv))
cvex.run(data_size, false);
// … do something with outputs
While this does not:
CVEX_Context cvex;
// … set up inputs
cvex.clear();
I didn't notice until this block of code was being run tens of thousands of times, so it's not a huge leak.
mark_visser
CVEX_Context cvex;
// … set up inputs
CVEX_Context cvex;
// … set up inputs
cvex.clear();
Hmmm… I'd have to see more of what's going on… The destructor of the CVEX_Context calls clear, so I don't see too much of a difference between the samples.
mark
You're right, mistake on my part.
It's very strange – it only happens when CVEX is run from inside a procedural. When the exact same code is called from a SOP, it doesn't leak.
I'm not 100% convinced it's a leak either. I just ran it through valgrind and it didn't report it. Could it be something global that CVEX is allocating that doesn't get freed until mantra finishes?
cheers,
-Mark
Found it… bad bounding boxes were forcing mantra to keep geometry in memory until the end of the render. Sorry for the false alarm. ops:
