Houdini Apprentice in UbuntuStudio 7.10
   7209   6   0
hi all.. I tried to install Houdini Apprentice in UbuntuStudio 7.10.
I changed the install path to /home/myusername/HoudiniApprentice/
It won't run. And tried $ ldd houdini-bin in the terminal.
this what shows up
xxx@ubuntustudio:~/HoudiniApprentice/bin$ ldd houdini-bin
linux-gate.so.1 => (0xffffe000)
libHoudiniAPPS3.so => not found
libHoudiniAPPS2.so => not found
libHoudiniOPZ.so => not found
libHoudiniOP3.so => not found
libHoudiniOP2.so => not found
libHoudiniOP1.so => not found
libHoudiniSIM.so => not found
libHoudiniGEO.so => not found
libcollada_dae.so => not found
libcollada_dom.so => not found
libcollada_LIBXMLPlugin.so => not found
libcollada_stdErrPlugin.so => not found
libcollada_STLDatabase.so => not found
libHoudiniAPPS1.so => not found
libHoudiniDEVICE.so => not found
libHoudiniUI.so => not found
libHoudiniPRM.so => not found
libHoudiniUT.so => not found
libpython2.5.so.1.0 => /usr/lib/libpython2.5.so.1.0 (0xb7e94000)
libutil.so.1 => /lib/tls/i686/cmov/libutil.so.1 (0xb7e90000)
libboost_iostreams-gcc-mt-1_33_1.so.1.33.1 => not found
libxml++-2.6.so.2 => /usr/lib/libxml++-2.6.so.2 (0xb7e6f000)
libxml2.so.2 => /usr/lib/libxml2.so.2 (0xb7d50000)
libz.so.1 => /usr/lib/libz.so.1 (0xb7d3b000)
libglibmm-2.4.so.1 => /usr/lib/libglibmm-2.4.so.1 (0xb7ce3000)
libgmodule-2.0.so.0 => /usr/lib/libgmodule-2.0.so.0 (0xb7cdf000)
libgobject-2.0.so.0 => /usr/lib/libgobject-2.0.so.0 (0xb7ca4000)
libglib-2.0.so.0 => /usr/lib/libglib-2.0.so.0 (0xb7be7000)
libiconv.so.2 => not found
libsigc-2.0.so.0 => /usr/lib/libsigc-2.0.so.0 (0xb7be0000)
libdl.so.2 => /lib/tls/i686/cmov/libdl.so.2 (0xb7bdc000)
libpthread.so.0 => /lib/tls/i686/cmov/libpthread.so.0 (0xb7bc4000)
libGLU.so.1 => /usr/lib/libGLU.so.1 (0xb7b41000)
libGL.so.1 => /usr/lib/libGL.so.1 (0xb7aaa000)
libXinerama.so.1 => /usr/lib/libXinerama.so.1 (0xb7aa7000)
libXext.so.6 => /usr/lib/libXext.so.6 (0xb7a99000)
libXcursor.so.1 => /usr/lib/libXcursor.so.1 (0xb7a90000)
libXi.so.6 => /usr/lib/libXi.so.6 (0xb7a88000)
libX11.so.6 => /usr/lib/libX11.so.6 (0xb7997000)
libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0xb78a3000)
libm.so.6 => /lib/tls/i686/cmov/libm.so.6 (0xb787e000)
libgcc_s.so.1 => /lib/libgcc_s.so.1 (0xb7873000)
libc.so.6 => /lib/tls/i686/cmov/libc.so.6 (0xb7729000)
/lib/ld-linux.so.2 (0xb7fe1000)
libGLcore.so.1 => /usr/lib/libGLcore.so.1 (0xb6d91000)
libnvidia-tls.so.1 => /usr/lib/tls/libnvidia-tls.so.1 (0xb6d8e000)
libXau.so.6 => /usr/lib/libXau.so.6 (0xb6d8b000)
libXrender.so.1 => /usr/lib/libXrender.so.1 (0xb6d83000)
libXfixes.so.3 => /usr/lib/libXfixes.so.3 (0xb6d7e000)
libXdmcp.so.6 => /usr/lib/libXdmcp.so.6 (0xb6d79000)
please help!
Did you run,
“source houdini_setup_bash”
from the directory where houdini is installed?
To keep things simple and predictable install houdini in /opt.
“everything is coincident”
I only got 900mb left in my root partition. Houdini Apprentice will eat 400mb. That's why I can't afford to just put it in /opt.
is there another way than putting it in /opt?
thanks in advance.
Still more important is whether or not you're sourcing “houdini_setup_bash” before you run Houdini. This will set all necessary environment variables like $HDSO, which tells Houdini where to find all those libraries that your not finding.
www.alan-warren.com
I already did “source houdini_setup_bash”
but still I have no luck..
hmm, have you tried setting any of the environment var's yourself? I wonder what would happen if you modified $HFS.
sudo gedit /etc/profile
place this anywhere in that file.
export HFS=/home/myusername/HoudiniApprentice/
restart or login / logout and try sourcing houdini again before starting.
www.alan-warren.com
hi everyone,
btw, thanks so much for replies
I already fixed it. I just want to share what I've done to fix it even though I'm not really sure about this.
In my first installation which is stated above. The error message “License Error: Unable to connect to hserver for license acquisition” always pops out many times. This is because I edited /etc/hosts changing “localhost” to "myusername".
I realized this after installing houdini apprentice in /opt and while playing with xampp [apachefriends.org] and /etc/hosts. It just triggered my thinking that it maybe about the /etc/hosts. And it was!!
I tried installing it again at /home/myusername/HoudiniApprentice/ then “source houdini_setup_bash”, reboot, then thats it. It worked like charm..
hope this helps. ^_^
