I just wanted to clarify the way and the settings to convert images to .rat files
as all I seem to get via a mplay conversion is .rat files that will not load and render when used as displacement maps.
R
Converting Files to .rat
3934 2 1-
- circusmonkey
- 2624 posts
- circusmonkey
- 2624 posts
- probbins
- 1145 posts
Regarding the loading problem, I'm reading between the lines here, but it is likely an issue with the file browser.
If you turn off “ Show sequences as one entry” you will likely be able to load your image. If a single image has a number at the end and you leave the “sequence” setting on, the image isn't recognized.
“everything is coincident”
