Having a little trouble with a houdini8 file in houdini 9
I am looking to re-render an old project which involved importing XSI models/rigs and animation into houdini.
With H9.1.124 (apprentice) I have tried it in exactly the same way as I did in H8.1 which was by placing all my .obj's a .clip file (called trans.clip) and an hsc file (called scenesetup.hsc) into a folder called Export.
I would then save a houdini file in another folder contained in the same folder as export.
Running the command source $HIP/../scenesetup.hsc in the texport would import all my models and animations.
Now when I do it in H9.1.124 it seems to import the geometry fine, however the file imported into chops doesn't work anymore and get the message Error: Missing Token: “ = /someFilepath/trans.clip”.
I'm running houdini on gutsy 7.1
Any help would be appreciated, as I would like to tart up some old work to make a showreel and the copy of houdini that it did work on was at my university so I can't use that anymore - eek
Cheers in advance
Fuzz
