Directory Navigation
   4246   3   0
When using the file dialog, on the left I see a few preset directories ($HOME, $JOB, etc…)
Does anyone remeber the trick to add your own directories to that list?
cheers,
-j
aren't they set in jump.pref?
which is text file in your $HH where you can add the jump-destinations which can also be environment variables defined in your shell.
see also:
http://www.sidefx.com/index.php?option=com_mailarchive&Itemid=212&view=WEB&msgid=6809fcad0804141207w7960e96dw7166a0624a591d01@mail.gmail.com&perpage=20&revdate=off [sidefx.com]
you can also add the current directory by pressing the ‘plus’ button below the list.
this is not a science fair.
hi!
While here can we have an RFE for:
- adding backspace for going back to previous directory
- pressing a letter on keyboard to jump to a file starting with that letter
just it would be useful
daniel bukovec | senior fx td | weta digital
qLib -- http://qlab.github.io/qLib/ [qlab.github.io]
I add a variable ie $project = “ your project path ” then to for paths within my scene file like textures. I just use $PROJECT/sourceimages/mytex.rat
R
Gone fishing
