st direction
   3630   4   1
Hi! I want to get s and t directions in sops.
Houdini is great! O'right?
I believe s and t are analogous to u and v.
-j
Hi, Jacob! I mean that I want parametrical primitive uv's directions. Not texture uv's directions
The UV Texture SOP has the option to generate uv's based on st (parametric uvs) for NURBs and Bezier Patches. Three options to choose from. See the help.
Meshes and Curves just use Rows and Columns option.
If you want to fetch the actual parametric value using expressions, look at:
unituv
primuv
realuv
uvdist
surflen
and more
In a textport type:
exhelp -k uv
and that will return to you all the expressions that have uv in their name or function description.
Hey, Jeff! Thanks.
