I have a fractured object that should fall apart. i set some initial positional and rotational values on the parts and discovered that the rotational velocity that is applied initialy assumes a wrong center (0,0,0). it seems that at the beginning the center is not calculated correct. how can this be solved
Martin
DOP:FracturedObject:Computed Pivot is wrong at the beginning
2857 0 0-
- sanostol
- 604 posts
