I wanted to dig deeper into volume rendering, but I encountered something strange.
With the basic smoke and billowy shader, the density parameter seems to have no effect. I checked the vop network which seemed fine, and tried to replace it a parameter of my own. And this time it has an effect, when it's 0 I get nothing, but I get a cube of smoke instead of a sphere of smoke, and the render looks weird.
I really don't understand what's going on.
As a side note, the way the billowy smoke shader is made, the amplitude for the noise has no effect.
I'm using 9.1.244.
Thanks for any help
Weird problem with smoke shader
7755 7 2-
- vinz
- 113 posts
- stevecullum
- 112 posts
- vinz
- 113 posts
- stevecullum
- 112 posts
- stevecullum
- 112 posts
- eetu
- 607 posts
Looking at billowy_smoke :
In the first post the parameter node in question is “density” which, as i understand it, is used to get the “density”-named attribute from the actual volume. That parameter is also toggled as “invisible” and doesn't show up in the material interface.
When you replaced it with your own constant parameter, you got a volume of constant density.
Steve C has probably been modifying the “Smoke Density” parameter in the material interface, which is different from plain “density”.
eetu.
(hope i got it right..
eetu.
- stevecullum
- 112 posts
- vinz
- 113 posts
Thanks a lot, that makes sense
Actually, the density parameter is not hidden (using 9.1.244 here), wether for the volume cloud, billowy smoke or basic smoke shader, which is what confused me…
Silly me, I'm used to using Cd and Alpha in my shaders, so the geometry attributes get used in the shader, but not density!
ops: , I wanted to write that I apply the shader to one metaball, with “metaballs as volume” checked.
