python script "on created" HDA
   4847   2   0
I would like to use something like :
hou.pwd().parm(“myParm”).set(666)
The doc says that the on created script is used just after the creation but it doesnt work for me ( 9.5 beta ).
Someone can confirm?
tky.
hou.pwd() doesn't work as you would expect in scripts attached to digital assets. If you were to just go ‘print hou.pwd()’ it would print the current directory in your scene, probably ‘obj’. You should use the dictionary that is created for python event handlers, kwargs.
You can then go:
kwargs.parm(“myParm”).set(666)
For more info about kwargs, just ‘print kwargs’ in your script.
Tky Graham,
Actually its documented in the HOM doc…
