Shattering Glass?
   7332   4   2
Can anyone explain to me how to do the shattering glass using Houdini 9.1?
hi
Houdini Product Specialist Stephen Tucker took the time and made a intro to fluids he, talks about that glass of water at the end
http://www.sidefx.com/index.php?option=com_content&task=view&id=1301&Itemid=282 [sidefx.com]
varomix - Founder | Educator @ Mix Training
Technical Artist @ Meta Reality Labs
I also posted an example a while back on odforce for how to actually build up the shatter network.
http://forums.odforce.net/index.php?showtopic=6257&view=findpost&p=46575 [forums.odforce.net]
Stephen Tucker
VFXTD
varomix
hi
Yeah, he's using 9.5 which has the shatter effect all simplified - I'll check odforce, thanks guys
Hi
I've done a file that show the basics of how the shatter tool in houdini 9.5 works, the shatter tool is just a HDA, and can be recreated by anyone, is not that hard.
Here's the file hope it helps you, and I do recommend that you get the 9.5 apprentice edition and dive into the shatter tool, it might be a bit more complex than normal because that tool tries to work for any kind, size and shape of geometry, so I has some stuff for that, the main cutting of geo is just a loop of grids with the mountain deformer applied.
Have fun!!
_mix_ManualShatter_v01.hipnc (68.2 KB)
