Hi everyone,
I am trying to install the Apprentice Edition v6.0 on my linux system, running Slackware 9.0.
Installing the files went smoothly. However, when I got to the licensing part and went to source houding_setup_bash, well, it did not work.
Here is the message I got:
line 104:
Has anyone had that problem when installing 6.0? Any fixes? I'm gonna keep looking around but I would appreciate any feedback on this one…
Thanks. nico
App. Ed. 6.0 licensing under Linux
6346 5 1-
- ndufort
- 4 posts
- black mariah
- 5 posts
- ndufort
- 4 posts
- stevenong
- 1634 posts
I believe there are users who have managed to get Houdini working on Slackware. Have you searched the forum?
Also, you might also want to search through force's [odforce.net] forum.
Cheers!
steven
Cheers!
steven
- wolfwood
- 4344 posts
I've been using Slackware 9 with Houdini 6 for a while now and I've been very happy. The only issue is Slackware 9 uses gcc 3.2.2 and Houdini 6.0.286 prefers Redhat 7's gcc 2.96. But if your not compiling plugins it won't matter.
To get Houdini 6.0.286 working on slackware you need to do two things.
First edit your houdini_setup_bash script.
Change the following line from
if ; then
to
if ; then
The second thing you need to do is adjust the license server stuff. For all the glory details try this post as od
http://odforce.net/forum/index.php?act=ST&f=2&t=452&s=7e23de1c5f13052106c81ca440a35662 [odforce.net]
To see why this works look at “/etc/rc.d/rc.sysvint”
This is the easiest way since the Houdini License Install will now work correctly. Another approach would be to edit your /etc/rc.d/rc.M so you don't have to create the RedHat style directories.
I got it working using both ways.
jim.
if ; then
to
if ; then
jim.
- ndufort
- 4 posts
