I'm finding myself in trouble with the $HIP variable–all my resource reference are set with it so paths don't break. But the problem is when my render queue manager runs hython on a remote server, $HIP points to $HFS/houdini/bin and all hell breaks loose.
So I'm trying to execute this script after the hip file loads so $HIP is set correctly.
path = hou.hipFile.name()
hipDir = path.rsplit(“/”,1)
hou.hscript(“set HIP=” + hipDir)
I can't figure out where to put this script to run it automatically at the start of a hip session. Any ideas?
Running a python script after a hip file is loaded
7434 1 1-
- IndyZoneCo
- 77 posts
- symek
- 1390 posts
IndyZoneCo
I don't think you can set $HIP. It just points to directory when hip file is saved, so it wouldn't have much sense. Once hip file is loaded, your $HIP should be properly set.
If you need to do something before the actual scene is loaded, you can use $JOB variable or anything else present in your environment. Render Manager usually runs a script which setup a whole environment before call mantra.
As to executing script on launch, 123.py (or 456.py for loading scene) placed somewhere in houdini's path ($HOME/houdinix.x/scripts or $JOB/scripts or $HSITE/scripts) does the job. Hard to say which place is right for you.
hth,
sy.
