Can I display texture in viewport?
   3294   1   0
thankU
The easiest way to use a UVQuickshade SOP.
Or ensure you have uv's on your geometry and then use a material like the “UV Map Material” from the Material Palette.
Or assign a shader (SHOP) with OGL Map parameters - like the VEX SuperMaterial, perhaps.
