how do you find the list of local variables?
   15022   5   1
best Ross
Try this
http://localhost:48626/expressions/_globals [localhost]
Rob
Gone fishing
Hi Ross,
Different sops have different local variables that you can use. If you are looking for a way to get to the different attributes that exist in geometry points, you can look into the point() expression also.
Ok… From a replicating SOP like Copy or Duplicate (are there others?) can I find out my own “index number” somehow? I want each of my 200 copies to behave a little bit differently… is there a $INDEX or something?
Thanks! == dvb
and for the benefit of future searches and google, here's the
variable list copied out of the 9.5 built-in help, of houdini expression variables with dollar signs.
Playbar variables
$FPS Playback speed in frames per second (as set with the Playbar controls).
$FSTART Frame number of the first frame of animation (as set with the Playbar controls). $NFRAMES (the number of frames in the animation) = $FEND - $FSTART + 1. See also $RFSTART below.
$FEND Frame number of the last frame of animation (as set with the Playbar controls). See also $RFEND below.
$F The current frame, (as set with the Playbar controls). This is a very useful variable, especially for rendered picture filename numbering.
$FF Floating point frame number.
$NFRAMES Number of frames in the animation. $NFRAMES = $FEND (the last frame of animation) - $FSTART (the first frame of animation) + 1.
$RFSTART Frame number of the first frame shown in the playbar. The playbar can show a subset of the total number of frames, allowing you to focus on a particular section of a long animation. $RFSTART and $RFEND control the subset of frames shown in the playbar.
$RFEND Frame number of the last frame shown in the playbar.
$T Current time in seconds. Equals ($F-1)/$FPS
$TLENGTH Total length of animation in seconds.
$TSTART Start time of animation in seconds.
$TEND End time of animation in seconds.
Global Variables
$PI The mathematical constant pi (3.1415926…). You can use it to calculate the lengths of arcs. 2*$PI*r (radius of circle) equals the circumference. Also, pi = 180˚ expressed in radians.
$E The mathematical constant e (2.71828…).
$HIP Job directory. This defaults to the directory where you started Houdini. You can set it through the Textport.
$HIPNAME The name of the current .hip file.
$ACTIVETAKE Contains the name of the current take.
Channel Variables
$OS Operator String. Contains the current OP’s name.
$CH Current channel name.
$IV In value (value at start of segment).
$OV Out value.
$IM In slope
$OM Out slope
$IA In acceleration
$OA Out acceleration
$LT Local time - not including stretch or offset
$IT Start time of segment
$OT End time of segment
$LIT Local start time of segment
$LOT Local end time of segment
$PREV_IT Previous segment start time
$NEXT_OT Next segment end time
COP-specific variables
$CSTART Start frame of the current COP.
$CEND End frame of the current COP.
$CFRAMES Number of frames for the current COP.
$CFRAMES_IN Number of frames available from the first input COP.
$CINC Gets the global frame increment value.
$W Current image width.
$H Current image height
Output Driver Specific Variables
$N Current frame being rendered.
$NRENDER Number of frames being rendered.
$CY is what you are after.
$NCY is the total number of copies.
It took me a minute… but I wrapped my head around the stamp function. Perfect!
I kinda wish there was a way to do STAMP_INTO_COPY_CONTEXT(“NNN”,$CY), to make $NNN become available to the copies. But hey fine!
Thanks keyframe.
