How can I map a simple quicktime movie on a polygon?
Thanx.
Uli
Map quicktime movie on a polygon
5226 4 1-
- ulikimmich
- 3 posts
- jason_iversen
- 12986 posts
You'll have to extract still frames from the movie first. Houdini can only write movies, not read them.
You can use QuickTime Pro (on Win/OSX) or perhaps mplayer (using a JPG output device) in linux.
Good luck,
Jason
Good luck,
Jason
- ulikimmich
- 3 posts
- rdg
- 401 posts
if your sequence is name tvseq.0001.jpg …
But houdini will detect image sequences if you select them throught the file dialog and place the correct expression.
$F = current frame number
$F4 is current frame number padded to 4 digits.
$F3 … 3 digits
$F3 … 3 digits
this is not a science fair.
- ulikimmich
- 3 posts
