I recently installed Houdini apprentice, however when I try to run Houdini the splash image comes up and then disappears and the program does not start.
Edit: When houdini starts it leaves an hkey process running but nothing happens, also when I try to run the licensing program alone the process is in the task manager but nothing happens as well.
I am running it on vista x64 home premium
geforce 8400 with the latest drivers
3gb ram
intel core2duo t8100
Problem getting Apprentice to run
3700 1 1-
- MattH
- 1 posts
- Chrizto
- 66 posts
Try re-installing, and choose license server as an option.
Also make sure your firewall is not blocking the license server from downloading the Apprentice license.
I would try to disable my firewall just for like 5 minutes, to see if that is the problem.
“If your life is not NOW, you're already dead…”
From Chrizto's book of truths
