is there an easy way to attach Geometry to Particles?
I tried to add an Instance Node, but I can't see the objects in Mantra.
Thanks for help
Greets Tom
Attach Geometry to Particles
10978 5 1-
- tomtm
- 133 posts
- sl0throp
- 258 posts
- tomtm
- 133 posts
- sl0throp
- 258 posts
- tomtm
- 133 posts
- sanostol
- 612 posts
If You want really instances with all their benefits and drawbacks, go to the objecct level select teh particle object and click on the little gear object at the top of the parameter pane, now select edit rendering parameters and search for the parameter “Mantra9.5>Instance>PointInstancing”, drag it to the right tree and click accept
now You got a new paramter Point Instancting at the objectlevel, turn it on and render. now You can see the donuts. by default the parameter is of so the instance information is not piped to mantra.
martin
martin
