i want to build a shader around general color theory that when colors darken they tend to get more saturated and/or change hue. usually based on color temperature, ie an orange ball wont just fade to black but will reach red first.
so far i have a mix node, mixing two colors using a lambert as the bias.
my question is can i somehow pull unshadowed lambert data? i know there are compositing workarounds, or i could use takes but i want to try keep it all in the shader.
and then the next logical question is how would i mix three colors?
thanks
to a man with only a hammer every problem looks like a nail.
What about using the color correct VOP and using the luminance out of a lambert node as a lookup for the hue / saturation parameters? See the attached example.
As for pulling unshadowed surface data, why not use an illuminance loop and “forget” to call the shadow shaders?
