HOT Houdini Ocean Toolkit Foam
   12930   3   1
Does anyone have an example hip file illustrating how to create foam (whitecaps) on a ocean created with HOT?
thanks,
bern
There is an example foamparts.hip in recent releases that demonstrates one way to go about this.
-Drew
drew
-Drew
u r eloop? can u give me a spray or foam shader example?
The best suggestion I can give is to look at the vopsop example foamparts.hip and the vex displacement shader in the docs. You will need to learn how to “export” from a displacement shader to a surface shader. There is no “plug'n play” shader provided.
-Drew/eloop
