Reverse keys by scaling
   6782   2   1
I would like to copy a bunch of keyframes, and reverse them later on in the animation. However, when trying to reverse the keys in time by sclaing them in the dopesheet, I can't scale them so they become negative. Only down to zero in time.
So my question is, how do I reverse a bunch of keyframes at the same time. As I am able to do in Maya by just scaling them in the X axis of the graph beyond 0 (to -1 normally).
you can do this in channel editor
select bunch of keyframes
press y to enable scale handle
now you can scale to negative
you can also adjust pivot point for the scaling
tamte
Thanks! Exactly what I was looking for. Couldn't find anything about it in the help for the channel editor. But that did the trick.
