Create group from node modification?
   4035   4   1
When I perform an operation such as a poly split, I want to create a group that contains all the newly created Points, how can i achieve this?
One way would be to append a group SOP prior to polysplitting, create a point group of everything, then add another group SOP after the split, then in the Combine tab of the second group make a ‘newpoints’ group != your first group…
J.C.
John Coldrick
Thanks for your advice, but I did not get it to work properly.
Since the new geometry created will have the highest vertex numbers, I wanted to group by an expression like such:
FROM: Object.TotalNumberOfVertices TO: ObjectModified.TotalNumberOfVertices
I know there is a variable called $NVTX which returns that value, however I do not know how to access it from within another node. I could use some help with the expression syntax here.
JC's method should work
test.hip (42.0 KB)
Stephen Tucker
VFXTD
Thank you for your example file, I understand it now.
