WIP: Ocean and ship interaction
   8688   8   2
Ocean and boat interaction splash
This is first try, still testing…
http://www.igorfx.com/Ocean/oceanWIP05.mov [igorfx.com]
WEB
http://www.igorfx.com/ [igorfx.com]
Vimeo
https://vimeo.com/igorzanic [vimeo.com]
nice work! I'm still trying to get the ocean toolkit working in windows 64
Hello CeeGee,
How do you get the points where to emit particles?
thanks,
bern
For interaction ocean and ship i use CookieSOP,
and for emit form ocean spray i use Cusp and Vel parametar form ocean
WEB
Vimeo
you should take a look at the “whitecaps” shelf tool. Gets similar looks to your particle spray pretty quickly.
Stephen Tucker
VFXTD
Allegro but for using whitecaps it must be a fluid ???
This is just a HOT and POP….
WEB
Vimeo
nope, whitecaps just requires a surface.
attached is an example.
I did notice a bug with it however… so you need to make the white caps asset editable, and delete the \ out of the expression for the source pop if putting the tool down from scratch.
test_wave.hip (186.0 KB)
Stephen Tucker
VFXTD
Thank you, resault is something like my setup…
But good to now another setup…
Thanks Allegro
WEB
Vimeo
Allegro
Nice work Allegro.
but why i open this hip file then shows warning: Skipping unrecongnized parameter “vm_volumefilter”
whats the problem here?
https://vimeo.com/jacyslin [vimeo.com]
