python in HDAs
   4330   5   1
Hey,
I'm writing some python for my HDA and have a very basic Q…
How do I get access to a parameter that's on the HDA itself?
say I have a HDA called “myHDA” which
lives at:
“obj”
if I put this code into the HDA python module:
def printHDA():
HDAName = hou.node(“..”)
print HDAName
and then connect this to a button.
It prints:
“obj”
shouldn't it be?:
“obj/myHDA”
I'm just trying to change a parameter on the HDA so I'll
need the code to be aware of what the HDA is called (in case its name changes)
I also tried:
def printHDA():
nodeN = hou.pwd()
nodeNFullPath = “obj/%s” % nodeN
HDAName = hou.node(nodeNFullPath)
print HDAName
this prints “None”…?
The next step would be adjust the parameter. But I can't get it to recognize the HDA.
I'm must be missing something really basic.
Pav
Hello Pav,
In both cases you where close.
In side your hda, you can use:
thisNode = hou.node(“.”)
this will return the current node.
The pwd() way works as well, it just does not return a node name but a node.
so
n = hou.pwd()
print n.name()
also works.
To get to the parameters, you can use the parm function on a node:
p = n.parm(“parmName”)
value = p.eval()
Hope that helps.
Koen
even simpler example…
if you have a HDA called myHDA in “/obj”
in the python shell:
myHDA = hou.node(“obj/myHDA”)
print myHDA
#results in: myHDA
myHDA
#results in: <hou.ObjNode of type myHDAOTL at /obj/myHDA>
in the HDA python module of myHDA:
def printMyHDA():
print myHDA
#will print “None”
:cry:
oh I see, yeah that worked…
Thanks koen!
Do you know why using the absolute path doesn't work?
Cheers
Pav
Because you gave it a relative path instead of an absolute path? I think you're missing the slash in front of obj. ie. you want:
myHDA = hou.node("/obj/myHDA")
oh I see.
Thanks.
