difference between delete and blast SOP
12075 2 2-
- sanfx
- 8 posts
- tkngs
- 105 posts
sanfx
what is difference between delete and blast SOP
From the online documentation on the Blast SOP:
Blast is designed to remove geometry that you select interactively in the viewport, as opposed to Delete which is a more procedural tool.http://www.sidefx.com/docs/houdini9.5/nodes/sop/blast [sidefx.com]
Whereas for the Delete SOP:
In addition to simply deleting unwanted parts of a model, this operator is useful for culling primitives from very dense geometry to speed up cooking of nodes downstream.http://www.sidefx.com/docs/houdini9.5/nodes/sop/delete [sidefx.com]
This operation can also delete profile groups (for example, 0.5 1.2-3.9) and mixed groups (for example, 0 0.5 4-12 1.2-3.9). It can also delete entire paste hierarchies or pasted surfaces, causing the remaining hierarchy to update. By deleting the root of a paste hierarchy, the whole hierarchy becomes undone.
Hope this helps.
tk
- old_school
- 2540 posts
