fur tools
   3774   2   0
Is it possible that with H10 if you attach fur to geometry you get some predefined lengths, density, render density in the fur node?
They are not the standard values (like if you CTRL-MMB on the values)
Is that changed since H9.5 ?
thanks,
bern
Bernard
In Houdini 10, density, length, etc. are scaled according to the size of the skin geometry. This ensures reasonable initial parameter values regardless of the scale you used for modelling. You will see reasonable behaviour if one unit represents one metre or one unit represents one inch.
Thanks Derrick,
that clarifies things.
bern
