how can houdini judge the corner of the polyline
   10386   9   2
hi everyone
Here is a simple question.
can houdini judge the coner points and seperate the polyline into different lines,I just want it to be procedurly.
here is the attached file. :?
ttttt.hip (42.7 KB)
I don't suppose a 2nd carve sop is what you are looking for? Using first U to locate the corner and keeping both inside and outside.
I would perhaps be nice if you could identify a specific point on the curve and turn on Breakpoints for that location.
“everything is coincident”
hi probbins
thanks a lot for your reply! I just think about the same thing.
The problem is clear now. How can I find the corner point by houdini:it is really confusing me a lot.
Use the poly extrude SOP
Find the normal that is not pointed in the same direction as the primitive normal.
Should be good to go!
cheers,
-j
jacob clark,thanks very much for your reply.
I will try it soon. :wink:
here is what I get now. The question is more and more approaching its goal. I can find the primtive normal and the point normal. But there is still some problems that I do not know how to put the point normal and the primtive normal together to compare. Hope some nice guy HELPS! :shock:
here is the hip file
ttttt.hip (54.6 KB)
could you remove inline points using the facet sop and then the end points the one left is the corner…..
Edited by - May 10, 2009 05:16:45
Thanks very much for you reply, Simon.
I take you method and work it out. It seems to be a good solution for the problem.
It is a part of a much bigger project, and there are still some problems.
Thanks for all the help you offer!
