Dear Readers:
I have some hexagonal tubes in a symmetrical arrangement, which I joined with a polyKnit and then closed up using a polyCap. The problem I'm experiencing is that when I subdivide the geometry the end areas where the caps occured are doubling up. I have attached jpgs for reference.
Can anyone suggest a solution? I'd hate to select prims one by one and blast them (I tried that but it's too tedious and can lead to selection mistakes).
Sincerely,
markerline
Doubled-up geometry after subdivision
4718 5 2-
- markerline
- 245 posts
- markerline
- 245 posts
- markerline
- 245 posts
- edward
- 8081 posts
- markerline
- 245 posts
Dear Edward,
Actually, I tried using a Facet SOP and consolidating points which I think is what Fuse does as well. In both cases this method did not work for me. If I Fuse AFTER the subdivide, points will get deleted and merged, but the result is unpredictable and not symmetrical.
EDIT: While writing this response and going back and forth between the post and the hip file I noticed I had duplicate geometry towards the beginning of the hierarchy. THAT was the root of my problem. Thanks for helping me to discover this. I now have what I want.
Sincerely,
markerline
Sincerely,
markerline
- Simon
- 2199 posts
