Hi all,
I am trying to do some scripting using the PyDev/Eclipse IDE. When I run something simple like this:
print hou.node('/obj').createNode('geo')
from within PyDev / Eclipse using hython.exe as the interpreter, it all seems to work. But I can't actually see Houdini - is there a way to make Houdini visible?
cheers
Patrick
Houdini is invisble
4153 3 0-
- phtj
- 224 posts
- phtj
- 224 posts
Hi all,
I am again looking at scripting in Houdini using eclipse/pydev
But am still a bit unclear about how this works…
It all seems to work, but I can't see Houdini - it runs in the background. Is there some way of making it visible, with the whole GUI.
Or is there some other way of connecting to a running full GUI instance of Houdini, so that I can see what the script is doing as it runs?
Cheers
Patrick
Cheers
Patrick
Patrick
- jason_iversen
- 13000 posts
If you haven't, check out the Python Masterclass: http://www.sidefx.com/index.php?option=com_content&task=view&id=1412&Itemid=132 [sidefx.com]
Usually this involves making sure you're connecting to houdini instead of hbatch.
- phtj
- 224 posts
