Hi ,
I have a sop solver operation I wish to execute. looking at the SOP solver help I use an Object merge with the following expression to pull in my geometry from Dops.
`stamps(“../OUT”,“DATAPATH” , “/obj/AutoDopNetwork/grid_object1”)`
This seems to work fine, except the other geometry within DOPs gets brought into the sop network aswell. In this case a torus.
I thought by using this expression only the grid object would be brought into the sop network. At other stages I am reading via the dopfield expression some values from the torus but at no time any geometry.
DOPs Sop solver
3297 2 0-
- circusmonkey
- 2624 posts
- jacob clark
- 665 posts
Hi Circus,
DOPs has a slightly different syntax for objects in it's contents.
http://www.sidefx.com/docs/houdini10.0/dynamics/io [sidefx.com]
Have a look at the 'Exporting simulation data to other networks' bit.
It should look something like …
`stamps(“../OUT”,“DATAPATH” , “/obj/AutoDopNetwork:grid/Geometry”)`
cheers,
-j
cheers,
-j
- circusmonkey
- 2624 posts
