SOP vector field node
   9040   6   0
I have a dop sim with 2 boxe falling into to ground.
I wanted one box to fall before the other, for that I used a mask field with a sop vector field referencig
an iso offset obj whit an transalte x animation.
but when i run the animation, the first box that's inside the the sop vector field falls, but wen the vector field moves to direction
of the other box, the other box does'nt fall…..
i've tryied the set allways in the sop path parameter of the sop vector field but it does'nt work..
what should I do?
is there any way else to do this without those nodes?????
here i attatched the hip file to be more explanatory
sorry the bad english
hip file.hip (122.3 KB)
you do not need sop vector field as a mask, Sop scalar field is ok. You do not have 3 volume primitives in your geometry anyways
but to your problem
see first attached file
for simplier solution you can animate activness of the second box by adding Active Value DOP and animating active parameter
see second file
hip_file_825_fix2.hip (120.6 KB)
hip_file_825_fix.hip (135.6 KB)
but i am actualy i am goin to do it with and RDB glue object with many peaces were i want some peaces to fall before the others , and i think with the activness animation i cant do what i want………
i am going to examine the hip files you sent me…..
than i say anything……….
then i suggest you to look at ChoreographedBreakup Example from help examples.
the technique used there can be used with active value or other (per object) parameters. But for your needs that example should be what you want
I had a look at this too and tried it with a glue object.
The scalarfield-method doesn't seem to work with it.
Jobless
edit: deleted
this was kind of doublepost because of some problems in the forum and missing posts
the scalar field example is about masking gravity by scalar field
which make no sense for the glued object since all glued RBDs are threated as one object and they will not separate this way
therefore i posted info about ChoreographedBreakup Example since krizard mentioned he wants to use RBD Glue obj
