hi
I have a problem with renderman rendering. The problem is that I cant render with renderman. everytime that I try to render with renderman my renderman node becomes red and I have this error
Error: command exit code: 127
there is nothing special in my scene, just a sphere, a light and a camera. Then I create renderman output node.
Thanks for your response.
(MACBOOK PRO 2.4 C2D) :cry:
renderman question
4085 3 0-
- souls7ealer
- 57 posts
- loopyllama
- 11 posts
renderman is not free and does not come with houdini. if you would like to use the renderman rop with prman you will have to purchase and install renderman.
if you are looking for a free option, you can try 3delight which graciously gives you 1 free license. after that is installed and licensed you can set the renderman rop to render with 3delight instead of prman.
- Alanw
- 320 posts
- souls7ealer
- 57 posts
