I am trying to join a curve to a nurbs surface and also to stitch to play around with it but can't seem to figure out how this works. So I have, for example a curve and a surface, both as geometry objects then when I go to join I don't see how I am supposed to select the thing to join it with. I have tried this also with cutting and pasting the second curve into the geometry object of the first but this doesn't seem to work either. It seems I am missing some aspect of this so if anyone can offer advice I would appreciate it.
edit: from looking at this a bit more it seems that you definitely have to be within a geometry object to use either of these but I just don't understand how you can effectively put 2 different pieces of geometry in here and join them, when I try to combine them and then go to do the join it doesn't seem to work.
How do you join / stitch anything together?
2643 3 0-
- rdane1010
- 120 posts
- circusmonkey
- 2624 posts
- rdane1010
- 120 posts
- circusmonkey
- 2624 posts
