Modelling arched windows
   3767   2   2
Hi list,
complete Apprentice newbie here.
I want to model a facade with many arched window openings. What is the best ‘Houdini’ way to do this procedurally?
I was thinking of building the windows as solid objects and use the cookie sop to cut them out of the facade. Is there a better way?
Thanks for your help!
That is one way. If your exterior wall has a thickness to it, then cookie is the best way to do it.
If you just have a single set of faces representing the exterior (no thickness to start off with), you can use the Hole SOP. See the attached file.
making_grilles.hip (161.0 KB)
punching_window_holes.hip (49.4 KB)
Thanks, Jeff. I will look at these examples.
