I've been banging my head against the wall trying to get a way for an arbitrary length array of strings (names of texture files) to be passed into a piece of vex shader code.
However the only thing there seems to be a gui for is the color and float ramp. Having to hardcode the file names in defeats the point.
The only way found is very dirty and involves a file being written from houdini for the vcc pre-processor to read in.
Any better suggestions? Thank you.
Fabian
How can I pass a string array into a shader?
4028 3 0-
- Fabian
- 127 posts
- niko3d
- 338 posts
I had the exact same issue. I have requested for an RFE to allow some sort of multiparm setup through vex. i.e We would have a set of parms under a folder which is tagged as a multiparm. Then in a similar fashion to a point cloud we run a while loop on a multiparm handle and this returns the requested data that we can store in an array.
Thus allowing you to create a library of textures or to have unlimited layering in a shader.
I would also like to see array support in vops, which im sure would help in making the multiparm set up more viable.
Cheers
Nick
Cheers
Nick
- Fabian
- 127 posts
- mrice
- 89 posts
