is it possible to copy/stamp to a specific polygons in a mesh? inside the geo context?
y just want to put some bolts in the center of some polygons using the normal of each polygon.
copy to polygons? or normals?
11884 5 0-
- pelos
- 625 posts
- elderic
- 24 posts
- Anonymous
- 678 posts
- pelos
- 625 posts
- probbins
- 1145 posts
The Copy sop should align your bolts to the template normals. You need to orient the bolts to the Z axis.
If you need more control then use the Align sop, but your bolt would then need to be a single mesh.
“everything is coincident”
- pelos
- 625 posts
Hi probbins, i thought i need to set the bolt in Y direction, so it fits. just looking up.
i saw several times the video on Houdini web site, they use nurbs and curves, according to the video the use position UV and W,
when i try to align geometry every thing explodes, i am not sure how to use the align yet.
they basic idea is to do a wing or some metallic stuff. select the polygons where i want bolts, make them a group, and then copy stamp with or with out align node the bolts to the polygons group that i created. and maybe later be able to do a asset out of this
i got the position to work, but for some reason the bolts are not keeping their form, they are becoming flat polygons.
.i got the position to work, but for some reason the bolts are not keeping their form, they are becoming flat polygons.
