Hi everyone
I am trying to create sun rays using volume light, i played with all attributes of volume light but didn't got the results which i wanted.
The process i went through is given below
1. Added a “spot light” and an “atmosphere” object into the scene.
2. Dropped a “VEX Lit Fog” in the shop network.
3. Got back to the scene and selected the “atmosphere” object, under the material tab selected the “VEX Lit Fog” shader.
Plz tell me were i went wrong & wht was the right process.
Any help from u guys will really appreciated,
regards
ranjeet
sun rays in volume light
23433 5 1-
- ranjeet.nikale
- 13 posts
- ragupasta
- 349 posts
- mark
- 2676 posts
ranjeet.nikale
Hi everyone
Why don't you just use a uniform volume object?
With a very low density, you can increase the step size considerably and get quite efficient renders.
Please see attached.
To get faster renders, increase the step size on the volume object. To get higher quality, smaller step size.
- ranjeet.nikale
- 13 posts
- th0rn
- 2 posts
mark
Hello. I have a weird problem with this scene. When I render it using the viewport render command (on the selector/handle toolbar) it renders fine, but when I create a mantra node (with default settings) the resulting image is white with some noise. There're probably some parameters that need changing in the mantra node but I can't find which ones are responsible. I'll appreciate any hints on this.
- th0rn
- 2 posts
