Houdini and analytical geometry
7126 7 0-
- asnowcappedromance
- 512 posts
- 512 posts
- graham
- 1926 posts
Wouldn't having control over the angles make it a non-equilateral triangle?
It's easy to setup a system so you can control the length of the sides for an equilateral triangle using the good old Law of Sines.
Since the triangle is equilateral, you know the central angle to each side is 120 degrees, forming an isosceles triangle with 2 angles each 30 degrees. You know the outer side, which is the value you want, so you just need to solve for r.
sin A/r = sin B/b
r = (sin(30) * desired length / sin(120))
Example attached.
sin A/r = sin B/b
Example attached.
- 512 posts
- graham
- 1926 posts
- graham
- 1926 posts
- edward
- 8085 posts
- 512 posts
