WIP - Water girl dance fountain
   16114   5   0
I was trying to do this effect with RF, and it was pain, then i try some fast setup in Houdini…
http://www.igorfx.com/RnD/girl_dance_RnD_v01.mov [igorfx.com]
http://www.igorfx.com/RnD/girl_dance_fountain_RnD_v01.mov [igorfx.com]
Particles are done in Houdini, no fluid or SPH.
With few force, mesh in Houdini, export as obj seq and render in Maya with Vray
Go to test more…
WEB
http://www.igorfx.com/ [igorfx.com]
Vimeo
https://vimeo.com/igorzanic [vimeo.com]
looks very elaborate, can't wait to see more!
why didn't you try a mantra rendering?
you used the particle fluid surfacer SOP ??
all the best,
Manu
http://vimeo.com/user2522760 [vimeo.com]
http://stormbornvfx.com/ [stormbornvfx.com]
Manuel Tausch
i was just test some workflow, Houdini Maya…
yes particle fluid surfacer
WEB
Vimeo
hi ceegee can you explain a little bit how you did the girl dancing with houdini?
how you did to keep the volume of the girl?.
This is one more idea for now…
http://www.vimeo.com/9363115 [vimeo.com]
WEB
Vimeo
Very nice
There's a fairly straightforward tutorial for getting very similar results in RF from digital tutors if you were looking. Or is that what your basing it on?
Just a suggestion, how about you give it some velocity inheritance?
