RBD shatter simulation - object loses it's texture
   5658   3   1
I have a basic RBD shatter simulation that I am really pleased with. Just one problem i have encountered - the object loses its material (applied with texture map to UVs).
this is a problem! is there a solution please? :idea:
mark2
You can apply the transforms of the RBDs back to the original geometry from sops using the DOP Import sop.
Something like this VVV
uv_chunks.hip (167.8 KB)
ahh thank you Ratmann, that helped to clarify what I am trying to do, which made me realise the dop import was using a different object name to what it was called in the AutoDop network.
thanks again
great example, thank you!
this is the sort of thing I normally get stuck on and waste a whole day with
